pennyporsche
3 hours ago, Jneffcpa said:
Need radio code for my 2001 Boxster. Did not receive code when purchased used.  Replaced the battery, and now have no radio. Serial #15040643.
Thanks for any assistance.
Try 8217
Share this post
Link to post
2 hours ago, Ilker Ucaner said:
Loren,
sorry for the the late response I had to wait for the “wait” to go away from my radio. I got what you needed ...
Info about my car ...
1998 Porsche Boxster
Radio: CDR-210
R3297
Serial: W5021992
Needed a radio code.
Best Regards!
 Thank you!
Try 8741
  • Thanks 1
Share this post
Link to post
27 minutes ago, bmatthew said:
CR220
serial #: Y5023926
Type: 4362
Thank you for your help with this.
Try 0765
Share this post
Link to post
Please can you help. I’m looking for a radio code for my 2001 Boxster S. Usual thing, replaced the battery, and now have no radio.
Details:
Type 4467
Serial No. 15046422
Share this post
Link to post
6 hours ago, mastertotebag said:
Hi Loren, Can you help me out?
CR-220
SN: Y5930562
Type: 4362
Try 0401
Share this post
Link to post
Details:
Type 4467
Serial No. 15046422
Try 7087
Share this post
Link to post
7 hours ago, Loren said:
Try 7087
Many thanks, back in working order!
Share this post
Link to post
Hi there!
I need the radio code for my Porsche Becker BE2360 stereo.
I tried an online company and got the code 0910, but the manual says that I need a five digit code and I can not choose the number O, only 1-6.
Serial number is: R1003095
Help is much appreciated!
All the best, Patrik73BE144C-3FF7-496F-8D58-DB6D39E452DC.thumb.jpeg.6045a1754582f42e8471d8015ed76117.jpeg
Share this post
Link to post
9 minutes ago, Patrik Dahlberg said:
Hi there!
Try 0190
Share this post
Link to post
10 hours ago, Patrik Dahlberg said:
OK, how do I get the 0, I have only the Numbers 1-6
Entering the antitheft CODE
This radio renders itself inoperative in the case of theft. If the radio or car battery is disconnected, the radio automatically disables itself. Once the radio is reinstalled or the battery is reconnected, the word "CODE", with a flashing letter "C", and the digits 1-0 appear in the display. Prior to use, the correct code must be entered via the multifunction keys.
Example: CODE 1530 (Preassigned to each radio and supplied to the owner on the PORSCHE RADIO CODE CARD) is entered by pressing the multifunction keys in sequence. After the first digit is entered, the word "CODE" disappears and the number is displayed followed by three dashes. As digits are entered, the next line in sequence flashes. When all four numbers have been entered, the first digit flashes. At this time you can overwrite the code as often as necessary. To correct any error, you must enter the complete code. Once the correct code is displayed, enter by pushing the signal seek switch.
If you have entered an incorrect code, the word "CODE" reappears in the display. The system allows two more attempts for a total of three. After three incorrect attempts, "WAIT" is displayed. A ten-minute time interval must lapse before you can attempt the coding process. You have three more chances to enter the proper code at this time. After nine attempts at code entry and three waiting periods of ten minutes each, the radio will "WAIT" for sixty minutes. After sixty minutes, you will have three more attempts at code entry. Should you fail at this point, "WAIT" will appear, and sixty minutes must pass before you can make another attempt.
Attention: The radio must be on during the waiting period.
Share this post
Link to post
5 hours ago, Loren said:
Hi Loren, and thank you for your answer.
i have the manual in which the text is from, but as the code you got for me is 0190, my question is still how do I get the number zero ( 0 ) , the Buttons only have the Numbers 1-6.
please advise,
All the best,
Patrik
Share this post
Link to post
please advise,
All the best,
Patrik
Thyen perhaps part of your display is out.
Share this post
Link to post
2 hours ago, Loren said:
Then perhaps part of your display is out.
The display is ok, but I have only buttons 1 to 6 to press on, look above, there is no button with the number zero on it, so the number zero in the code 0190 is impossible to create.
Also the manual says that there is a five digit code needed, not four as you got for me.
Any thoughts?
Best Regards, Patrik
Share this post
Link to post
1999 Porsche boxster
Type: 4462
Serial Y5046732
Need a code please
Edited by Mylesr
Share this post
Link to post
Any thoughts?
Try 51131
Share this post
Link to post
Type: 4462
Serial Y5046732
Need a code please
Try 4709
Share this post
Link to post
9 minutes ago, Loren said:
Try 7387
Worked like a charm. Thanks again.
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
