pennyporsche
Boxster 2001
Becker traffic pro
serial# 25005875
looks like a 5 digit code?
thank you
Edited by pierre robert
Share this post
Link to post
1 hour ago, pierre robert said:
Boxster 2001
Becker traffic pro
serial# 25005875
thank you
Try 13211
Share this post
Link to post
Hi!!! Thank you for your work here!!!
99 boxster lost radio code
CDR 220
Type 4462
Serial W5002283
Much appreciated!
- shawna
Sent from my iPhone using Tapatalk
Share this post
Link to post
CDR 220
Type 4462
Serial W5002283
Much appreciated!
Try 2637
  • Like 1
Share this post
Link to post
Hello,  Very grateful for any help!
1999 Boxter
Becker CDR 210
Type: R 3297
S/N: V5011131
Appreciatively,
AlexQS
Share this post
Link to post
1999 Boxter
Becker CDR 210
Type: R 3297
S/N: V5011131
Appreciatively,
AlexQS
Try 4542
Share this post
Link to post
Hello,
Trying to keep the 996.2 Bose system with Becker radio and the 2nd hand replacement unit came without codes.
CR 22
BE 4367
Y5030237
BR,
Jussi
Share this post
Link to post
Help new to me 1999 Carrera 4 dead battery and radio says wait.
How do I get code
CR 220
becker 1
type 4362
47/98
X5013531
Share this post
Link to post
6 hours ago, piethein said:
Hello,
CR 22
BE 4367
Y5030237
BR,
Jussi
This is your third request for a different radio code - please consider a donation to this site.
Try 2649
Share this post
Link to post
How do I get code
CR 220
becker 1
type 4362
47/98
X5013531
Try 8768
Share this post
Link to post
I found that number written on the paper option tag on underside of the bonnet.  I did try it but it didn't work.  Do you have to hit enter after.
thanks for the help.
art
Share this post
Link to post
art
No.
If the code I gave you did not work then chances are that your radio was repaired by someone other than Becker. If that is the case then I can not help you... sorry.
Share this post
Link to post
Just bought a 1999 boxster
Radio # WSOO7525 (LCD messed up, the second O may be incorrect)
VIN# WP0CA2982XU627459
Thank you for any help.
Share this post
Link to post
Try 1296
Share this post
Link to post
Can I bug you if you have a free moment to help me find my code?
2002 996 Turbo
CDR-220
Serial #: 25011950
Thanks in advance
Share this post
Link to post
Try 2649
Thanks.
Code worked like charm.
Donation done for a good cause.
BR,
Jussi
Edited by piethein
Code worked.
Share this post
Link to post
I am looking for a code for my 996TT
CDR23 = eda5f2deef8abbs
Radio = BE661225017063
Any help would be appreciated.
Thanks in advance.
Sam
Share this post
Link to post
2002 996 Turbo
CDR-220
Serial #: 25011950
Thanks in advance
Try 4821
Share this post
Link to post
5 hours ago, Sam Newman said:
Thanks in advance.
Sam
Hmm... didn't read the Lost Radio Code FAQ...
CDR-23 (or later):
Share this post
Link to post
I also have a request for a radio code. The vitals are as follows;
Model. CDR210
Ser No. V5010232
Any help will be greatly appreciated.
Share this post
Link to post
Model. CDR210
Ser No. V5010232
Try 2609
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
