pennyporsche
On 5/14/2019 at 6:42 PM, Loren said:
No.
If the code I gave you did not work then chances are that your radio was repaired by someone other than Becker. If that is the case then I can not help you... sorry.
The code was correct and the radio is working fine, thanks.  The contacts on the back of the radio must not have been making good contact, so the buttons 6 to 0 were not working.
thanks for your help
Share this post
Link to post
Well, before I disconnected battery, I thought I wrote down what was the code.  But it didn't work.  So then I did the Tone-8-0 and got the serial number, which matches what was stamped on the side of the radio (labels were no longer there).
Please provide the code for the following:
BE2182
W501609
R3297  <-- 3297 is what I originally wrote down as the code, but apparently it isn't since it shows up when I electronically checked the serial number.
Kevin
Atlanta, GA
Share this post
Link to post
BE2182
W501609
Kevin
Atlanta, GA
Try 4171
Share this post
Link to post
1 hour ago, Loren said:
Try 4171
My apologies, missed a digit in the S/N.  Below is the corrected S/N.
BE2182
W5010609
Share this post
Link to post
Hey Loren,
If you get a chance, can you help me out with an unlock code?
2002 Boxster base
CDR-220
Type: 4462
Serial: 15003179
Edited by gurbleflaxis
Share this post
Link to post
BE2182
W5010609
Try 4361
  • Thanks 1
Share this post
Link to post
4 hours ago, gurbleflaxis said:
Hey Loren,
2002 Boxster base
CDR-220
Type: 4462
Serial: 15003179
Try 4546
Share this post
Link to post
Hello!
Would be so happy if you could help me with the code too..
2000 boxster
CDR-22
type: 4467
serial: Y5023319
Thank you// Sebastian
Share this post
Link to post
1 hour ago, Sebatron said:
Hello!
2000 boxster
CDR-22
type: 4467
serial: Y5023319
Try 2735
Share this post
Link to post
1 hour ago, Quentin Sebring said:
1999 Boxster
CDR-220
Type: 4462
Serial: X5018991
Thank you in advance
Try 7658
Share this post
Link to post
Just finished rebuilding my engine and re-installing it... and yep, realized I don't have the radio code.  Ugh.  My Radio is a CDC-3, and the Serial is W1024450.  Are codes still available via this thread?  Thanks!
Share this post
Link to post
CDC-3 is a CD Changer, not a radio.
Please read the Lost Radio Code FAQ.
Share this post
Link to post
Just got a 1999 911...radio needs a code please?
CDR-210
R3297
W50 19399
Thank you!
Share this post
Link to post
CDR-210
R3297
W50 19399
Thank you!
Try 9658
  • Like 1
Share this post
Link to post
Try 9658
That worked!  Thanks so much!
Share this post
Link to post
Howdy,
I would appreciate getting the code for my radio since I'm about to take it out and add an AUX connection.
2001 Boxster
CDR-220
Type 4462
Ser. No.: Y5045277
Thanks much! - Carl
Share this post
Link to post
19 minutes ago, RKCarl said:
Howdy,
2001 Boxster
CDR-220
Type 4462
Ser. No.: Y5045277
Thanks much! - Carl
Try 8938
Share this post
Link to post
Hi I need the code to my 2000 Porsche Boxster Radio:
Becker CDR-220
Type: 4462
Ser: Y5035485
24/99
Hope you can help me with this. John
Share this post
Link to post
Becker CDR-220
Type: 4462
Ser: Y5035485
24/99
Try 1356
Share this post
Link to post
I have a BE 6627  S/N 55045802 I need the radio code. replaced instrument panel on y 06 cayenne and now it reads protect on screen.
Any one know what I need to do?
TH
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
