pennyporsche
7 hours ago, Rwilson said:
Appreciate help recovering lost radio code. Here is the info I obtained from my radio.
Thank You
Just found your site and signed up. Need to spend quiet time with content, if as good as first impression will become a supporter.
thanks again
Becker 1
type 4462
ser# Y5050368
24/99
Try 0876
Share this post
Link to post
Hi There!  What a wonderful service. I have
typ: CCR220
Model No. BE6624
Serial No. 15001008
Many thanks
Share this post
Link to post
typ: CCR220
Model No. BE6624
Serial No. 15001008
Many thanks
Try 9059
Share this post
Link to post
22 minutes ago, 1964john996 said:
Mines a CR-220
type 4362
WS002977
Your help is greatly appreciated
Cheers
Try 4847
Share this post
Link to post
Hi, I have a Boxster S 2003 with the radio locked due to dead battery. Hope someone can help me.
Model BE 6612
CDR23
Serial # 25008219
Marc
Share this post
Link to post
Model BE 6612
CDR23
Serial # 25008219
Marc
You did not read the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DMEand can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
Share this post
Link to post
1 hour ago, Dademurphy said:
I have a CR-220
Type 4362
Serial: Y5024889
Your help is much appreciated!
Try 7098
  • Thanks 1
Share this post
Link to post
5 hours ago, Mark Wallace said:
Hi Guys.
In need of some help.
1999 Boxter
Becker CDR 210
Serial W5022641
Thanks in advance
Try 4237
Share this post
Link to post
2 hours ago, Mark Wallace said:
is it just putting the code in and it will work or do i need to hit any other keys
4237 didn't work
Did you get your serial number using the procedure in the Lost Radio Code FAQ? If not, please do so and resubmit the correct serial number.
if you did use the procedure and the code does not work then it is likely that your radio was repaired by a 3rd party (someone other than Becker Sound). If that is the case I am sorry but I can not help you.
Share this post
Link to post
Hi
having just bought a  boxster and having the battery replaced the radio no longer works
I have googled to get the model/serial no and have the following info if anybody can help
Thanks in advance
CDR-22
Type:- 4467
Serial :- Y5036253
Edited by Monroe7986
Share this post
Link to post
50 minutes ago, Monroe7986 said:
Hi
Thanks in advance
CDR-22
Type:- 4467
Serial :- Y5036253
Try 4972
Share this post
Link to post
Hi Loren, do you mind helping me out?
I have a CR-220
Type 4362
Serial #: 15040044
Thanks a lot--much appreciated!
Share this post
Link to post
I have a CR-220
Type 4362
Serial #: 15040044
Try 0352
Share this post
Link to post
I have a CR-210
Type R 3297
Serial #: WS010961
Many thanks!!
Share this post
Link to post
I have a CR-210
Type R 3297
Serial #: WS010961
Many thanks!!
Try 8683
Share this post
Link to post
8 hours ago, TheFlapjack said:
How do you find the radio type? Have a CR220, 2000 911. The label on the radio is worn off.
Read the Lost Radio Code FAQ and follow the procedure there - then post here.
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
