pennyporsche
2 hours ago, Eeflex11 said:
Hello second owner with no radio code
radio serial number is 15002268
CDR-220
2002 Porsche Boxster
thank you very much for what you do
Try 2517
Share this post
Link to post
I have a 1999 Boxster and just ran into the radio code issue. Any help is very appreciated!
CDR220
serial #: Y5054498
Edited by JamieFL99Boxs
Share this post
Link to post
CDR220
serial #: Y5054498
Try 5234
  • Thanks 1
Share this post
Link to post
I need a code as well please. 98 Porsche 996
my friend didn’t give me the radio code and disconnected the battery. LOL
CR-220
4362
W5009094
47/98
Share this post
Link to post
CR-220
4362
W5009094
47/98
Try 5651
Share this post
Link to post
Hey there!
We just placed a new battery and seem to be missing the code (rookie mistake)
All help appreciated!
CR-22
4367
X5017025
49/98
Thanks 🙂
Share this post
Link to post
2 hours ago, Samski66 said:
Hey there!
CR-22
4367
X5017025
49/98
Thanks 🙂
Try 1391
Share this post
Link to post
This is a truly awesome service!
Becker CDR 210
Model R2896
Serial# T500119
Have been advised of the code but suspect its utter tosh. Attempted to enter 4 digit number (have the display CODE with flashing C) but attempt to enter the code results in it going straight to display Becker with <> arrows directly below
I may very probably be doing something wrong but stuffed if I know what. Is there a particular procedure other than punch number in?
Share this post
Link to post
Becker CDR 210
Model R2896
Serial# T500119
Try 4536
Share this post
Link to post
Hi guys, hope you can help me. I’ve a 986 with a CDR22 radio and battery went flat asking for code now.
The code from from pressing the TP button o got is below plus the model:
25009587 and type 4467
need anything else to help me, much appreciated
simon
Share this post
Link to post
Hi Loren,
Looks like a step in the right direction... But
When I enter first number as soon as I release the button the second number is automatically populated by 0
Any suggestion?
Share this post
Link to post
simon
Try 1916
  • Thanks 1
Share this post
Link to post
24 minutes ago, RichardMoon said:
Hi Loren,
Any suggestion?
You may then have a problem with the radio.
Either repair (Becker Autosound) or replacement.
Share this post
Link to post
Hi
I have a 2000 Porsche Boxster that I need the radio code for
it’s a cdr-220
serial #x5038155
can someone please help
Share this post
Link to post
10 minutes ago, Scoobyvanz said:
Hi
it’s a cdr-220
serial #x5038155
Try 9409
Share this post
Link to post
12 minutes ago, Vessie Wilson Richardson said:
I just bought a 1999 Boxster and disconnected battery without knowing it needed a code:
model 4462
serial X5023793
Try 2432
  • Like 1
Share this post
Link to post
1 hour ago, Christophe Let said:
I just bought a 2002 Boxster and disconnected battery without knowing it needed a code:
model cdr 22
model 4467
serial 15002706
Try 8341
  • Thanks 1
Share this post
Link to post
On 8/19/2019 at 11:35 PM, Loren said:
Try 1916
Amazing guys, worked perfectly thanks very much
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
