pennyporsche
16 minutes ago, Loren said:
If 9104 does not work then chances are your radio has been repaired by a 3rd party (not Becker) - in that case I can not help you. Sorry...
Thank you vey much for the effort, I got the radio of eBay from a dismantler, so I don't know if it was repaired.
Share this post
Link to post
Just picked up today. 99 Carrera!! Woohoo!    CDR 210.                                              R 3297.        W5020876.          Thank you much.
Share this post
Link to post
Try 0835
Share this post
Link to post
Hi. I really need the code what i lost for my boxster PLEASE!!
Becker cdr 22
model be4467
serial 15038467
THANK YOU!!!!
Share this post
Link to post
Becker cdr 22
model be4467
serial 15038467
THANK YOU!!!!
Try 7561
  • Thanks 1
Share this post
Link to post
On 8/22/2019 at 4:39 PM, Loren said:
Try 0289
That works !!
Thank you !!
Share this post
Link to post
Hi Could you please help me with a lost radio code for a 2000 Porsche 996 twin turbo
VIN:WP0ZZZ99Z1S681301
Raido: CDR-32
Type: 4667
S/N : 45022228
THANKS!!
Edited by cam777
Share this post
Link to post
Raido: CDR-32
Type: 4667
S/N : 45022228
THANKS!!
Try 8612
  • Thanks 1
Share this post
Link to post
I need help with my radio code for a 2001 Boxster S
Type 4462
Serial # 15087058
CD  CDP2081
Thank you!
Share this post
Link to post
Type 4462
Serial # 15087058
CD  CDP2081
Thank you!
Try 5239
Share this post
Link to post
27 minutes ago, Gotpointers said:
Thank you very much in advance! I appreciate your help
2000 911
Becker 4462
X5025562
Try 5656
Share this post
Link to post
Evening, I'd love help with my code, Please.
02 911 C4S
CDR 220
Model BE 6625
Serial 15007997
Thanks in advance,
Manny
Share this post
Link to post
02 911 C4S
CDR 220
Model BE 6625
Serial 15007997
Thanks in advance,
Manny
Try 7392
Share this post
Link to post
Hello,
I had to change my battery and didn't have a voltage saver and so lost my radio code.  I have a Becker CDR 220 Type 4362, Serial 15050689.  Would anyone be able to help me with the four digit unlocking code?
Thank you in advance.
Share this post
Link to post
1 hour ago, Michael M 986 said:
Hello,
Try 8585
Share this post
Link to post
2 hours ago, Ole Jensen said:
Hi, I need a code for a 996.
Type: IDIS BE 2580
serial: 15079249
Thank you!
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
  • Similar Content
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
