pennyporsche
Hi Loren,
Hope you can help a newbie out from the other side of the pond......
Just bought my first 986 yesterday and it needs a radio code
Type: CDR-22
Model: BE 4462
Serial: X5012417
Thanks in advance Antony
Share this post
Link to post
25 minutes ago, MadAnt said:
Hi Loren,
Type: CDR-22
Model: BE 4462
Serial: X5012417
Try 0878
  • Thanks 1
Share this post
Link to post
47 minutes ago, Loren said:
Try 0878
Excellent Loren thanks for the quick response.
I now have a working radio & CD player...😊
Share this post
Link to post
Hi everyone, new to the forum. I just changed the battery in my 1999 996 Carrera 4 and now I need a PCM code that I don't have. Not sure what radio it has but it is am/fm/navagation with 6 disk changer in the bonnet. Any help will be greatly appreciated.
Share this post
Link to post
Didn't take the time to read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Share this post
Link to post
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Boxter 1999
Becker CDR 220
type CDP 2081
serial # Y5045543
CARRO WPOCA2989XU631931
Thanks for your help 🙂
Share this post
Link to post
16 minutes ago, FEDERICO OQUENDO said:
Hello,
Boxter 1999
Becker CDR 220
type CDP 2081
serial # Y5045543
Try 5404
  • Like 1
Share this post
Link to post
I could use help with a code for my 1999 Porsche Boxster:
Cr 220
When I press the tp button these are what I get:
Ser: X5013077
47/98
Type 4362
Gal:00
Aux OFF with up and down arrows underneath.
Thanks so so much!
Share this post
Link to post
Cr 220
Ser: X5013077
47/98
Type 4362
Gal:00
Thanks so so much!
Try 1046
Share this post
Link to post
On 9/26/2019 at 4:32 PM, Loren said:
Try 1046
I need more help I guess.  I've tried entering the 1046 at several points and nothing works.
The stations buttons are not numbered so I'm assuming that it's 1-9 and then 0.  Or does 0 come before 1?
At which point do I do the 1046?  What should be showing on the display when I press the station buttons?
Thank you so much, I really appreciate your help!
Share this post
Link to post
Lost Radio Code FAQ
Share this post
Link to post
Replaced battery in 1997 Boxster and need unlock code please.
CR-210
Type: R 2095
Serial: V5004615
Edited by jdhutton42
adding more info
Share this post
Link to post
  • Similar Content
    • By Sonsalla911
      Hey Guns,
      i one a GT 3 mk 1.
      it has Original Radio CDR 23And weites Protect.
      when i Check with PIWIS there is a Site with Radio Code which is now 0000.
      i Could change But have no Code.
      who can help me...i thought CDR 23 will Never loose Code
    • By Sonsalla911
      Hallo ,
      can someone help me to change frequence from CR 2200 from Asia to Europe?
      Warm regards. Ingo
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
