pennyporsche
Need radio code please.
Becker CDR220 sn Y5060295
Try 6696
or
6694
If you have not already read this FAQ - please do so...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Read the FAQ, got the WAIT display, waited for an hour, got the code request again, tried more codea and got the WAIT display again. Is the WAIT function what happens when the wrong codes are entered before you can enter more codes?
Yes, wait means you have to wait for the time out perod before you can enter more codes.
Share this post
Link to post
Hi guys. There's a handwritten 4645 on a sticker under the hood. I guess it may be my radio code, and while I don't need it just yet, I'd like to have it when the time arises. Is there a way for me to check to see if this is the right one?
Edited by tgt40
Share this post
Link to post
Please read this and follow the instructions...
Share this post
Link to post
Hello , i need to know code from my radio. last i got no batery on my boxster 2001 and when i put the newer there, radio acquire a code, please find this for helping me . here is the information:
becker 1
4467 24/99 gal : 00 ser: Y5036206 CDP2081 Let me know, if you can help. Thank you
Share this post
Link to post
becker 1
Try 1012
or
1010
Share this post
Link to post
Hello,
my friend needs to know code from his radio. He gave me these information:
becker 1
4467
24/99
gal : 00
ser: Y5036206
CDP2081
Pavel
Try 1012
or
1010
If you have not already read this please do so...
I have just got message from my friend. One of them worked. :thankyou:
Share this post
Link to post
Need a code for a 1999 966 Carrera CDR-210 Mod#-R2896 SER#T5001491. Thanks
Try 8826
or
8824
Hi Loren, thanks for the codes but unfortunately they did not work. Any other suggestions, greatly appreciated.
Yes, READ THE FAQ.
The answers are in there!
Share this post
Link to post
Hi, I am looking for the code to unlock my CR-1 radio in my 1995 993... the radio# is .. POCR-1R0218953B.. tks for the help.. Norbert.
Do you know if it is a 4 digit or 5 digit code?
Share this post
Link to post
No sorry.. have no idea...Norbert
Share this post
Link to post
For my Blaupunkt decoders I have to know the number of digits. You can always try a friendly dealer/ OPC.
Share this post
Link to post
  • Similar Content
    • By Steven Powell
      My CR-220 plays the FM & AM & Cassette, doesn't play the 6 Pack CDs. Faceplate does not display, all presets work, and equalizer.  Is the problem in the face plate or radio?  Will getting another faceplate work with this radio?  Will it change the radio code.
    • By Ig.ny
      “Thank you worked like a charm!!!! I have a foxwell, getting error codes 31 ignition circuit - side airbag , driver
      and 21 ignition circuit, driver
      no idea what to do. Horn works depending on its mood. “
      Please help
      Any suggestions  would help. I’ve taken off the door panels and disconnected and reconnected the airbags.
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
