pennyporsche
Boxster 2.5L
UMM? Its a manuel transmission its a ==== 5speed + Reverse, so whats that, Sorry :huh:
TAN
US
:) THANK YOU.
I need your radio serial number.
Please read this and follow the instructions...
Lost Radio Code - FAQ, PLEASE READ THIS FIRST
Thanks for responding
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
If you have not already read this FAQ - please do so...
Share this post
Link to post
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
Please tell me how much i owe you, Thank You, I appreciate it.
-What other types of Codes are You able to get, such a key programming, or specifications such as how to program a key remote alram, Thank You :)
Share this post
Link to post
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
I entered the 1st number, it went back to code.
i entered the 2nd number, but i think the last number wasnt pressed correctly and it went back on code.
The third time i re-enterd 2511 and the "WAIT" message is displayed, any Ideas
Thank You!! :huh:
Share this post
Link to post
Hi
I have a 1999 Carrera with a "CDR 210" Ser # w5018912 .
I change the battery and do not have the code for the radio.
Any help with the 4 digit code would be appreciated.
Thanks David Collins
Share this post
Link to post
Please help, changed battery and I can't find the code. Here are the details
Serial Y5047492
Year 2001
CDR-220
4462 Type
24/99
CDP 2081
Share this post
Link to post
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
Key program codes (IPAS codes) must be obtained from an Authorized Porsche dealer/ OPC. Then you need to protect hem because anyone in possession of those codes could program a key and steal your car.
Share this post
Link to post
Boxster 2.5L
TAN
US
:) THANK YOU.
Becker 1
4462
48/98
X5020732
Thank You. :)
Try 2513
or
2511
Thank You, :D
Thank You!! :huh:
READ the FAQ.
Share this post
Link to post
Hi
Try 3441
or
3439
Share this post
Link to post
Sorry, I just figured out where to post this request
2001 911 Cabriolet
6spd, Black on Black
Radio Type CDR220 (4462)
Serial # 15061937
Thanks in advance,
Chris
Share this post
Link to post
Thanks for this awesome forum, it's a huge help. I have a 2001 Boxster, 2.7L H6, 5 Spd. I just changed the batter and discovered that none of the original materials has a radio code. Here is the type and serial number:
SER# Y5045220
Type is 4462
Thank you so much for your help!!!
Best regards,
Mark
Share this post
Link to post
SER# Y5045220
Type is 4462
Best regards,
Mark
Try 4898
or
4696
Share this post
Link to post
2001 911 Cabriolet
Serial # 15061937
Thanks in advance,
Chris
Try 4715
or
4713
Hi again,
I have tried both codes, either do not work, any ideas??? Thanks
Yes. READ the FAQ.
Share this post
Link to post
Hello,
I had a dead battery on my 1998 Boxster. I bought it used and do not have the radio code.
1998 Porsche Boxster 2.5
5 Speed
US model
Becker CR-210
Model R1996
serial # V5005255
Thanks for your help!
Share this post
Link to post
Hello,
5 Speed
US model
Becker CR-210
Model R1996
serial # V5005255
Try 8762
or
8760
Share this post
Link to post
Hi, I hope someone can help. I have lost the radio code. this is the info I have found. I'm not sure how to go about getting it. Any help would be appreciated.
Becker 1
type 4467
seri 15003447
24/99
Thanks John
Share this post
Link to post
Becker 1
type 4467
seri 15003447
24/99
Thanks John
Try 0926
or
0924
Share this post
Link to post
  • Similar Content
    • By Kevin Bryck
      2002 996
      Welcome everyone to another installment highlighting the wonderful world of fragile Porsche parts!
      Have both 17" and 18" wheels and have recently lost the metal Center Cap logo medallion off of one wheel of each size.
      While removing the other center caps every remaining medallion fell right off in my hand.
      Metal medallion secured with a random dab of some type of adhesive.
      We have reached the end of lifespan of whatever adhesive the Center Cap supplier used to keep precious colored metal medallions stuck to those cheap plastic caps.
      Anyone know how to remove old adhesive?
      Anyone have any idea what adhesive to replace it with?
      Anyone know how much the Porsche/Piech families made selling replacement center caps last year?
      Remember when paying through the nose for your precious replacement Center Caps that the Porsche and Piech families are the 7th wealthiest oligarchs in the world per Wikipedia.
    • By Loren
      Which radios fitted to Porsche can have their unlock code recovered through serial number?
      - CR-220/CDR-220 - Becker
      - CR-210/CDR-210 - Becker
      - Traffic Pro NAV/CD - Becker
      Which radios can not have their unlock code recovered through serial number?
      - CR1 - Alpine
      - CDR-23/24 (or later) - Becker
      - PCM (Porsche Communication Management) – Siemens & Becker
      How to get your radio serial number?
      CR-220/CDR-220:
      Hold down the TP button for at least 10 seconds after you turn the radio on. "Becker 1" will be displayed. Rotate the right knob (slowly) and it will display the Becker model number. Then rotate it again and the serial number should be displayed on the radio.
      Or, if the radio is out of the car the then the serial number is on the label.
      CR-210/CDR-210:
      Press tone, then 8 and 0 simultaneously. "Becker" appears. Press station up arrow on right. "PR-VERS" appears. Press one of the numbered buttons below the display, directly below the LCD arrowheads (try a few). The model number will appear. Press station up arrow on right. "SERIAL N" will appear. Press the numbered button again. The serial number will appear.
      CDR-23 (or later):
      These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected.
      Traffic Pro:
      Select the Service Menu, press NAV and multifunction key 10 simultaneously in radio mode. Use multifunction keys Nxt and Prv or turn the right control knob to select the individual items.
      You can move through the following items:
      - Model-No.
      - Serial-No. <-- this is what we need
      - Changer Reset
      - GAL
      - Radio Software
      - Radio Bolo
      - Navi Rom
      - Navi Flash
      - RTC Value
      To quit the service menu, press END.
      I get a WAIT on the display - what do I do?
      You have to wait at least 30 minutes before trying again.
      The suggested number did not work - what do I do now?
      Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
      If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
      Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work.
      Can you give me a code for my PCM?
      These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
      Sorry, the only place you can get a PCM code is from a dealer/ OPC.
      Can I post my VIN to get a code?
      We do NOT need your VIN - only your radio serial number.
      Where can I post my lost code request?
      Please post your request here:
      Please DO NOT PM me or email me (or anyone else helping with the codes) your radio code request - we will only answer requests in that one thread.
    • By mdhall54
      I have a 2003 Boxster with the CDR23 radio and external amplifier mounted in the front trunk.  There are two multi-pin connectors, a fiber optic connector and an antenna connector on the rear of the head unit.  The display on the head unit in the car seems to be fine as the display appears to be working as it should.  The problem is no sound out of any speakers.  The problem was intermittent for quite a while as sometimes when I started the car I would have sound from  the speakers and other times no sound.  Sometimes I would be driving and the sound would suddenly just quit.  Now there is no sound at all, but the head unit display still appears to be working ok.  Does anyone have any suggestions as to what might be the problem?
