TRG Rear Sway - Torque Specs?
I'll be installing TRG's rear sway bar and drop links next weekend. Can someone give me the torque specs for the various nuts and bolts that I'll be working with?
I checked the M030 ROW install DIY and didn't find the specs for the sway bar and links. Are they there and I'm just being lame?
Anti-roll bar mating bearing to spring strut (M52 x 1.5) (lock nut) - 911 GT3 -- 50 Nm (37 ftlbs).
Anti-roll bar to side member M10x1.5 -- 65 Nm (48 ftlbs).
Anti-roll-bar mount to anti-roll bar M10 - 911 GT3 /911 GT3 RS -- 55 Nm (41 ftlbs)*
Anti-roll bar mount to spring strut M10- 911 Carrera 4/911 GT3 -- 46 Nm (34 ftlbs)
Anti-roll bar mount to wheel carrier M10- 911 GT3 RS -- 50 Nm (37 ftlbs) **
* 3-stage tightening procedure. First Tighten to 50 Nm (37 fllb.). Then loosen by 90° and then tighten to 55 Nm (41 ftlb.).
** Coat threads with Loctite 243 before fitting. Tighten all threaded connections immediately.
Thanks Loren, appreciate the quick reply!
