hello people i have a my 06 987 i got a fault message today ,, pasm faulty indicator ,, after pressing sport button message failure sport mode dissappears after a few seconds 1st message stays it feels like the suspention is in de sport mode it is harder than in normal mode pressing the pasm button no cure no lights on either buttons (sport or pasm) after parking car i can hear a humming sound near the schockstrut area maybe pasm control solenoidsvalves on shockabsorbers ?? any thoughts ? thanks alexander
Edited by alexander987
Sounds like the shock has failed. Take the car to the deailer where they will hook it up to the diagnostic equipment and tell you whats going on. Its likely to be a warranty fix so first call is with them.
Regards
Popolou
update took car to dealer today fault can not be cleared and no software can be loaded pasm control unit is dead it does not communicate with the syst and it needs to be replaced it has to be ordered from germany syst goes to a failsafe mode if it can not communicate with pasm control unit solennoids on shockstruts are energized and in sport mode pasm fault message on screen no reaction on pasm or sport button if pressed message failure sport mode solenoids on strut are powered with contact on and off and car locked so it will drain the batterie only by removing batterie cables you can shut the syst down i keep the car on a batterie loader untill replacement next thursday
