Instrument cluster PN#
Do you have PSM?
MY99 did not - it had TC.
Not sure if I have the PSM or TC is there a way I can check? It's a 2000 c2, I do have two extra (yellow) connectors not hooked up to anything in the center upper console and not sure if this would be used to turn on and off PSM? If I do not have PSM would that be the difference "warning light" for the instrument console?
TC was only MY99 so you don't have it. I doubt Porsche would carry both parts if either would work.
Maybe Tool Pants remembers what those connect to - I don't off the top of my head. Maybe seat heaters?
Even porscha scrathed their heads on connectors, the ones for the seat heaters are black and white I beleive. Regarding the cluster mine is not turning off (RPM, Speed digital lights). I want to try one to test but buyng it and it not being the problem would set me back unecessarily. Thanks for the help.
