Problems selecting reverse
I would start by inspecting the the cable connection on the transmission. One cable is for forward gears the other is for reverse.
If everything there looks good then you need to remove the center console and check the cable connection and the bottom of the gear selector to see if the gimbal joint is worn or crackedc.
