Front Passenger Seat Stuck In And Wont Slide Back (997 S)
Hi guys,
I'm hoping this is a simple fix. The fromnt passenger seat is stuck and wont slide back. The switch works and the motors seem to be running but the seat is just not budging. Any suggestions
In my 996 the switch is very sensitive to how it is placed. One time I was vacuming my car and I knocked off the switch. I put it back on and couldn't get the seat to move forward it would only go back.
I drove over to my mechanic and all he did was take it off and put it back on again. I had misaligned it slightly.
He said unless it is on perfectly it won't work properly.
Does your switch come off? The 997 may be different but you may want to take off the the little plastic fob and put it back on again. Make sure it precisley on the little pin.
Hope this helps.
Phillipj
