:help: drove my car over the weekend ( 99 C4). Notice that the fan up front /radiator kicked in when I started the car and did not stop until i turn the car off. I think its the first time that this has happen or i never pay any attention to it before.
I let the car idle for 25 minutes in the garage; car did not over heat.
My undersdtanding is that the electric fan only kick in to cool the car; not on at all times. should i be concern? The is not over heating, but I don't want it to lead to other problems.
TIA.
Did you have the Air Conditioning on? The AC will ask for the rad fans to come on if the pressure is high on the condenser side. If so, try it with the AC off and see if it still does it.
