hi all
have a fault on a carrera 3.2 with g50 gearbox . very intermittently clutch pedal sticks down low until you pull it back up then its ok again for a week or so.. cant see any fluid leaks from master/slave cylinders . all looks clean around pedal area . thinking poss master cylinder fault . any input greatly recieved
thanks simon
Sounds like the clutch master cylinder is by-passing internally.... best to replace the master and slave then flush the entire hydraulic system.
