Switched power in center console/dash area?
Is there a source of ignition switched power (for a V1 install) available in the center of the dash where the radio is, or down by the cubby area / heater seat switch panel in an 04 996 non-PCM? I'd like to avoid routing wires from the fuse box area.
thanks,
Simon
Hi Loren,
Any advice on removing this panel, or do I just grab it somewhere and pull hard? Don't want to break anything.
Also, do you know if the mute line mutes the radio when connected to ground or +12?
thanks!
Simon
