Can anyone tell me if the pic's below are correct? Shamefully, I never opened the center console before I took it out of the car and it's been a while since I tore it down (I know, should have taken pictures). Thanks for the help.
Been a while since I have done that - but it looks okay.
It will only work (and spring open) one way - so if it works as normal it is likely correct.
I wasn't sure if the lid should open further (don't want to break the hinge).
Not much further than shown - but if your hinges are plastic instead of metal now would be a good time to replace them. The plastic ones all break (sooner or later).
Hello again Loren,
I just bought a 1999 996 and the center console lid is broken (as you have stated above). Please advise me on a repair. It looks like I'll have to replace the complete console as the only thing holding the lid on is the little strap.
Thanks for any help,
Patrick Ford
Hello again Loren,
Patrick Ford
:welcome:
Broken Oddments Tray Hinge DIY
