Tightening Torque For Wheels
jecey
Does anyone know what the tightening torque should be use for the wheels ?
I need to remove the wheel(s) to check if the dealer didn't forget to remove the rubber stop blocs on the springs. :soapbox:
thank you.
thanks Loren.
I got a look, but nothing wrong.
I guess that the sway-bar is somewhere disconnected on the right side.
On top, the car is deviating on the right ... definetely need to go to the dealer on monday to fix the problem, and to check the set-up.
