See the thread in the 986 Boxster DIY forum. It is the same as a 2000 2.7 Boxster retrofit.
Thanks a lot for your answer, but is it also ok for a 996 C4 2001?
  • 3 months later...
Are the add cruise instructions in the Boxster DIY section applicable to a 04 996 GT3?
Yes. Treat it the same as a MY2003-4 Boxster. This requires connections between the cluster and the stalk, and a feed from the fuse B7. No connection to the DME is required. PM me, and I'll send you the wiring diagram.
