I was considering putting a ROW M030 suspension on my '99 C2 Cab (US). However, after looking at the distance between the rear fender and the tire, I was afraid that the fender would have to be rolled. I saw in another topic here that showed pre vs post M030 install distance from the ground to the fender well. It showed ~27.5" pre and ~26.25" post. I measured mine as it sits and I and at 26" rear and 26.5" front. From first glance it does not appear to have any aftermarket shocks or springs and I do not have any suspension option codes.
My questions are 1) Is this ride height normal? 2) If this is low, could it be that the stock shocks/springs are worn causing it to sit lower (car has ~65k miles)? 3) Is there an easy way to determine if an aftermarket setup has been added?
TIA
Will
Perhaps someone put springs on the car previously?
Either way if you change to RoW M030 it will come to the ride height as specified.
No fender rolling is required as long as you use factory wheel widths and tire sizes.
