Hi guys,
I am a relatively new 1999 996 C2 owner with 54,000 miles. My brake wear sensor turned on so I followed the very helpful DIY article to replace the front pads. I am concerned with how my old pads wore. The outside pad of the front passenger side wheel was worn significantly more than the inside pad of the same wheel. That outside pad was the only one triggering the sensor. The inside pad thickness was not close to triggering the sensor and neither were the two pads of the front driver side wheel. Should I be concerned, and if so what should I be looking for?
