Hi to all
When I change up a gear I get a little hesitation( jerking motion not smooth gear change) in the car. This is most evident when moving slow or with normal street driving especially from first to second. If i hold the clutch a little at the end of a shift it is a smoother shift. With more agresive driving there is no evidence of it. The car had a new clutch flywheel etc the issue was evident before this. I had my first DE event this week and the car was great on the track. The instructor noticed the lack of smoothness while in the pit but not on the track. He suggested dirty injectors. any body have an idea on the problem or a possible solution.
thanks
Christopher
MY99 911 ocean blue manual cab
How many miles?
When were the plugs changed last?
Have you inspected the coils?
When have you last cleaned the throttle body?
I doubt it is any injector issue (maybe he was a 993 or 964 driver ;) )
How many miles?
thanks loren
I have 57200 miles now
plugs were changed at about 53000 as per your DIY (thanks)
I do not know what bad coils would look like(any photo)
I cleaned the throttle body two weeks ago.
thanks
Christopher
Loren
I have the car up off the ground
I have not taken the coils out but i have taken a closer look at them, I see littie cracks around where the allen screw holds them on. would this be enough to cause the issue. I dont know how to claen the MAF and i am reluctant to touch it as i have read of others having problems after. is there a way to check the coils when removed to see if one is bad.
the part code on two off the coils is beru 996 602 102 00 (the rest are blank) I have had no CEL or no misfires.
Hi loren
I checked the coils all have a little crack of some sort 1 to 2 per coil . i checked the resistance and got 0.5 Ohms on each at about 55degrees so they all pass. what should i try next. I got a price of $50 per coil so i would rather have a definate result before replacing them.
thanks
Christopher
Was the fuel filter changed recently, also a fuel injector can cause your issue. Try some techron or similar to see if it helps!
