I tried searching but could not find the answer even though I remember reading it. On a 2006 997 S Cab, how do you remove the DME and where is it located?
Less than 2 hours... No patience eh?
Make sure the key is out of the ignition and the battery is disconnected - FIRST.
Preliminary work for DME control module in Cabriolet
1. Removing cover over the motor
1.1. To loosen the carpet, pull out the plastic clips with a trim pry tool and take out the carpet.
Removing DME control module in Cabriolet
1. Unscrew the four fastening screws 1 for the control module and lift it out.
2. Press in the connector and pull it off the control module A.
3. Press in connector B latch and actuate the latching lever.
Thanks... and Sorry, I have to Fedex it out today. Is it located behing the passanger rear seat?
Edited by hjacobs2000
It looks urgent !! Place the convertible hood in service possition, the DME = CARTRONIC is located behind the trim under the convertible/clam shell in the environment of the hydraulic pump, 2006 is probably screwed on. Hope it helps.
Is it the same location as the convertible hood motor?
