Folks.....
Apparently my turbo heat shields are corroded and require replacing and my exhaust heat shield in most places is loose. Is there a quick easy method of doing the jobs rather than removing the turbo's and exhaust etc??
Please advise?
Cheers,
Dave.
Remove the rear bumper shell, the light alloy bumper and the secondary heat shield. The exhaust heat shield is bold on the exhaust, look what's happen, could be loose bolds or rusty shield. To replace the shield you have to remove the exhaust, which is not difficult, and you got better access to the turbo shields.
