HI !
I have my new boxster 2005 with 30k miles and I'm having some intermittent starting problem ,the starter turns but it looks like it has no ignition. Then i stop starting it, do it again and then it starts very well, and it's not happening all times maybe one on ten, no matters if the car is cold or warm.
thanks
Ben
Check DME and fuel pump relay for proper fitment and good efficacy, located above the fuse box.
