Boxster 99- Top switch assembly
Boxster 1999 - soft top control - Switch
It appears that pressure on the switch causes one side to come free causing an intermittent contact.
The switch assembly is very lose because of the 2 screws/bolts that hold the assembly in place to the windshield frame go into (2 plastic retainers) which are cracked, so the botlts do NOT tighten and leave the sw assembly lose. When I go over a little bumpp, both windows go down a few inches faking the sensor to think that I want to put the top down.
What I am looking for is the parts # for the 2 white plastic retainers where the screws go inThank you
