loose/chattery noise when in reverse.
Hi all,
When i reverse my 2000 boxster s, there is a very loose and chattery sound from the rear of the car. Dipping the clutch makes it go away but when I let the clutch up again to reverse the same chattery loose noise starts again. The noise is only there when reversing.
Any ideas or pointers would be appreciated.
Many thanks.
need to check the linkage cable,often times cable has a enough slack to chatter.
might be able to fix it by zipping it with a wire tie
Hi all,
Many thanks.
