Is the front hood adjustable?
To some degree yes. Look for the two rubber bump stops on the inside front edges of the hood.
It is also possible that your front bumper is not proper aligned.
When properly aligned the front bumper should be even to just slightly higher than the front hood (otherwise you will have wind noise).
