Stock Front Suspension issue
Gentlemen,
My 02 C2 makes a distinct rattling noise in the front suspension area but only under low speeds. During any sort of spirited driving the noise is gone (and I don't believe just masked by other noise) I've been hearing the noise for a while and it is staying about the same, I have looked and can not see anything broken. The suspension is completely stock and I am having no issues with braking.
James Huber
02 911 C2
Gentlemen,
James Huber
02 911 C2
Mine is same year, model, etc, 40k miles & does the exact same thing. Took lower shields off and found nothing loose. Figured it has to be either control arm bushings or upper strut bearings (which definitely groan once warm). Not worried about it, but hope it goes away when I eventually update/replace the suspension. Let me know if you find anything & I'll do the same!!
