Bumper cover small damage repair
Thermo-plastic does weld, but it is dificult to obtain a weld strength that is the same as the original moulded part strength. However good results can be found.
Plastic welding is the same as other welding in that you need to use a filler of the same material, many plastic repair shops will have a pile of ruined old parts that they can use for a filler. If you only need a small amount of filler shave some stips of the back of your part, if you need a lot go to your breakers yard.
Do not use a flame with your welding as this will cause oxidation and poor weld strength, try using a soldering iron or get the proper equipment which would be a hot air plastic welder.
Hope this helps
