After much time and effort of confirming rear centre console part numbers and returning incorrect parts the interior is finally finished.
Apart from the Aluminium look interior change I also had the Porsche Short Shift kit installed. All gears from 1st through to 6th are fine, reverse on the other hand is a nightmare. Need to take the car back tomorrow for some minor adjustments. I can barely engage reverse and my wife has no chance. Not sure what is causing it but I am certain it will be sorted out tomorrow.
Edited by ArthurK
Hi Aurthur,
I had the Porsche Short Shift Kit installed a few months ago and I did notice (In my case anyway) that reverse is slightly more notchy to select (especialy when the gearbox is cold) compared to the other gears - otherwise it is no real drama to select reverse.
I'd say that it just requires a minor adjustment.
Your interior looks great - I really like the Aluminium touch on the instrument surround.
- You just need an Aluminium Dead pedal for a RHS vehicle - I have not seen anyone selling these though - :angry:
Costas.
Yes the reverse is slightly more notchy but this requires brute strength to push left then finally up. I can barely get it into gear as it is so I cannot see how my wife will. It is going back tomorrow for some fine tuning.
With respect to the dead pedal, I have a LHD dead pedal just need to pull my finger out and get it machined. I was hoping my wife could do it (she is an engineer at Holden (GM for the yanks :) ) but no luck.
Thanks for your kind words on the interior
My C4S has the short shifter installed as a factory option. I don't notice any difference on shifting to reverse from other gears. They should be able to make some minor adjustments to fix the problem.
