When I did the DIY, I found any variety of extensions were helpful. I didn't have a 4" but made due with other pieces.
+1. I think I had about 3 smaller extensions to get to them.
I used multiple short extensions, it was definitely a pain in the rear to change out the plugs (must have relatively small hands).
+1 on the PITA.
I ended up removing the rear bumber and mufflers to get good access to the most difficult plug holes.
JP
+1 on the PITA.
JP
The trick to making this job easier is removing the mufflers not the bumper.
See the DIY for more on this.
+1 on removing the mufflers, otherwise you may need a small indonesian child to reach the rear passenger side one for you.. :censored:
When I replaced the spark plugs on my 99/996, I shortened a hex head/allen head to remove the top hex bolt on the coil packs, the allen rench ended up looking like a small L. For me removing the coils was the worst part of the job.
