This isn't a pressing issue, as the Boxster won't be moving around much in this snow... but I figured I could tackle this now rather than wait for summer.
Have any of you had a kink or otherwise leaky windshield washer line? I pulled the car out a little this morning to get the snowblower out for the winter. When I went back to the garage to put the snowblower and Pcar away, I tried to use the washer fluid to help melt away the snow that had accumulated on the car as I left it outside (stupid me!) but there was no fluid. I made sure the nozzles were clear, and topped off the tank, and tried again: Same issue. I kept the motor going for ~30 seconds, but not a drop. When I pulled the car back into the garage, there was a melted blue spot from where it appears the fluid I had tried to use on the Windshield was re-directed to instead. The garage is heated, and I doubt the fluid would have frozen in the half hour the car was outside. I've read on another forum I frequent that some owners are experiencing mouse infestations around this time of the year... While I see no evidence in the garage of mice, I want to see if the line is simply unplugged, or if it has been chewed - don't want to replace a wiring harness in the spring! Could someone suggest a method of getting to the tank / lines to see what is going on, put my mind at ease, and possible solve this problem?
Thanks in advance,
Bry
Thanks in advance,
Bry
Bry:
The washer tank, motor, and lines are easily accessible and viewable if you remove the black plastic inner fender liner. You can get a good look just by removing the liner from where it is attached to the rear part of the driver's side front wheel well.
The fasteners are self-explanatory, but it sometimes takes a little extra effort to pull the liner out of the inner lip of the fender at first.
Regards, Maurice.
Check the washer tube connection behind the battery, sometimes the valve comes open, to start with. A second well know leak is the small tube on the water tank which come loose from the connection.
