I used the wrong oil - 0W-20
hi all,
I used the wrong motor oil when i did my oil change a month ago. After reading some post and looking at one of my empty bottles, I discovered that I had used 0W-20 instead of 0W-40. Should I change the oil right now? or can I wait till my next oil change to go back to 0W-40. Thanks everyone for the help.
Only the complete quantity will give the right specifications, sad.
Maybe all (or all the oil) is not lost. 8 quarts of 0W-40 and 1 quart of 0W-20 will give viscosities of 74.7 cSt at 40C and 13.4 cSt at 100C. These values are within 5% of the 0W-40 spec's. This should not be a problem for street driving. If the car is going to be tracked then it should have the 15W-50 in the first place. I wonder what the viscosity tolerance is during Mobil 1's blending and bottleing.
0W-20, eh? The Mobil 1 website lists only two 0W-20 oils. One is a racing oil that will not be available until Spring 2009. The other is an Advanced Fuel Economy oil. The racing oil has the advantage of twice the amount of anti-wear additive. However, that could shorten the life of the cat. converters. The fuel economy oil is just thin to cut friction.
Interesting topic.
RennTechers, enjoy the holidays!
Thanks all, its not all 0W-20. I had 0W-40 in there and topped it off with 0W-20..... My next oil change is in 200 miiles (for me, that is a week of driving)... I will swap out all the old oil and replace it with 0W-40... Thanks for everyones help.... happy holidays....
