PCM 1 Code needed
Hi Loren, Just had to put a new battery on my 2002 996 Carrera 4S manual with PCM and have no stereo or Nav as i dont have the security code . :angry: I have carefully removed the PCM Headunit but am not sure which serial number you require as there is 2, 1 on a Becker sticker and 1 on a Siemens sticker so i will provide data from both.
Becker Sticker as follows.
Type; IDIS
Model No; BE 2580
Serial No; 25100699
Siemens Sticker as follows.
Serial No; PO8150096218/01
Do hope you can help, Happy New Year Tim.
:renntech:
Type; IDIS
Model No; BE 2580
Serial No; 25100699
:renntech:
Sorry, the only place you can get a PCM code is from a dealer/OPC.
