'83 911SC electrical - coil question
ericinboca
1983 911 SC won't start. We don't get a spark - either out of the wires from the distributor cap, or straight out of the coil. We swapped out the coil twice with two new ones, and still don't get a spark either way.
We have power to the coil - BUT - how much power should be getting to the coil?? Maybe there is indequate voltage getting there for the coil to do its thing.
The CDI module has most likely failed, it's often a leaking or overheated ignition coil that damages the module. With the ignition key on you should be able to hear the module making a very high pitched noise. It's located in the engine bay on the left side near the hinge area for the engine cover.
Edited by wvicary
We went through the diagnostic yesterday. Someone along the way in the life of this 911 has made some electrical changes, so I don't have a definitive answer. But we heard nothing out of the CDI module and did determine there is power to it. It goes for a bench test this week, and a likely rebuild. (We found a guy in FTL, FL that says he can rebuild for $220 with a 5 year warranty. Intersting -- we will see.)
