Failure Convertible Top Control
Thanks, but that wasnt it. The lid was the first thing I checked. I guess the next question is... If it is trully a control error, the how can I manually get into the back to check the control unit with the top in the down position?
Edited by hjacobs2000
I would disconnect the battery for a couple of minutes, reconnect and try again. It is still possible that the control box is dead, especially when the battery ground cable was not disconnected from the chassis during the charge. You can close the soft top manually, a little complicated but reasonable, see owners manual.
Ive been trying to lift the top manually via the owners manual instructions and I can not get it to budge more than 6 inches up. I tried it with one person on each side as well as form behind the fronts seats as stated. It seems to be stuck on the hydraulic lifts. Any recommendations ?
