Painting Roll Bar
Question for the forum: Has anyone painted their rollbar, or is it just too hard to get right?
Is it worth removing the bar all together to have the body shop spray it or should I just mask it up and have at it?
Guest barry
It's a big job to remove the rollbar, so I painted the hoop portion (~above the door line) in-place using automotive spray touch up paint.
I removed the trim panels, seat belt brackets, etc., sanded and cleaned the roll bar, VERY carefully masked off and covered anything that could get overspray, and then did the deed. You'll need to move the top into a couple of intermediate positions to get to the horizontal bar below the hoops, but it's not too difficult.
Not quite factory quality, but not bad...for about $10 and a couple of hours of time.
  • 2 years later...
