Man I love Sunset!
Just wanted to give a great thanks to Sunset Imports, and inform some people of a few great prices!
I needed some replacement parts for my 00' Boxster S, and I couldn't find anywhere else to beat the prices.
I got a brand new HVAC Control Unit (my old one's digital readout screen was almost dead) - $241.00
The Plastic trim piece that covers the Security Alarm blinking LED light - $20
The driver's side triangle plastic trim piece that houses the side mirror controls - $18
10 quarts of Mobil Synthetic 0W-40 - $5.00 a quart!!! That was WAY cheaper than my local autozone or pepboys around here.
And of course the filter and o-ring - I can't remember what the filter cost, but the little metal o-ring was $0.47. :)
I ordered a bunch of door paneling replacement clips as well... I think I got 2 bags of 10 for about $2.48 as well.
Also curious... Anyone know the part # and how much the pull-arms for the front and rear hoods are (just the silver pull-arms, don't need new springs or anything). Mine are all scratched up.
Kudos
Kudos
Do you mean the hinges? The thing that attaches to the body and the lid, and to which the gas pressure spring is attached?
If so, for the front:
996 511 151 01 (left)
996 511 152 01 (right)
Rear:
986 512 151 01 (left)
986 512 152 01 (right)
Kudos
:sunset:
Kudos
Rear:
I mean the actual "silver levers" that you "pull upwards located on the driver's side that release the hood and the rear luggage compartment. Mine are all scratched up from shoes hitting them, and some of the paint is chipped off.... looks crappy which is why I want to replace them.
Kudos
Rear:
Ah - I wasn't even close.
I found these for '00:
996 551 511 03 handle lacquered /LLV00
996 551 511 03 v01 silver
996 551 512 03 handle lacquered /LLH00
996 551 512 03 v01 silver
996 551 511 04 handle lacquered /RLV00
996 551 511 04 v01 silver
996 551 512 04 handle lacquered /RLH00
996 551 512 04 v01 silver
I'm not sure I know what all this means, but I would think it is the "04" silver ones. Not sure if I am helping much. Sorry. Maybe someone else can decipher the part numbers.
Edited by ericinboca
I'm expecting a boat load of parts for my '84 911 next week from Sunset. They are BY FAR the cheapest place I've found for OEM stuff. Great service and their prices can't be beat.
Thanks for the tip on Mobil 1 0W-40! I'll be getting my next oil change stuff from them!
Keep in mind you can order a replacement LCD screen for your ventilation control unit from eBay vendors for about $52. You have to disassemble the control unit, but the replacement is easy (even for an idiot like me) and the new display works well.
I just got a bunch of stuff as well from Sunset. Aaron in parts is Great! Front Engine mount $147.23 Vario Cam solenoid $126.57 clutch pedal pads $3.88
They resized them. I did mine last year. There's no more shaving of the parts or anything complicated. It's plug and play now with great directions. But you're right in the fact that the numbers and icons on the display aren't EXACTLY the same.
Yea, I know about the replacement screen... but it's not "exactly" the same screen, involves some shaving and modification, and I wanted the OEM unit. So that's why I went with that over the replacement screen.
Yep, I just replaced my screen in November and it was plug and play. For the budget conscious, it's a really good way to go. If you want the display to be stock, then this option isn't the best.
+1 it's a really good way to go
