996 top of dash LED plastic cover removal
Does anyone have a good photo of the removed LED cover in the centre of the top of the dash right next to the windscreen?
I'm worried as I try to pull this that it's going to break. It's pretty solidly fixed. It would be useful to know where is best to lever it.
I want to remove it to get a wire down to the inside of the dash so that I can mount a small radar detecgor on the top
of the dash next ot the LED cover.
I used this spot for the gps antenna from my DNX 5120 and it was perfect, there is a steel base under the cover that the magnetized antenna sat right in and by opening the plastic where the alarm wires pass down you have a clear shot to the back of the center stack. :D
