Are there a diy to swap a 911 6spd tranny in the boxster? I already have the engine, I'm also tempted by a tranny from the same car.
Advantage and dis-advantage?
I have a 5spd right now btw, non-egas
You will want a Boxster S 6 speed - a 996 transmission will have the pinion gear on the wrong side (and you will have 6 gears in reverse and 1 forward).
The Boxster engine/transmission is turned 180 degrees from what it is in a Carrera.
