I track my 997C2S a fait amount, and have a lot of melted rubber on the wheel wells and cannot seem to remove it.
Anyone know of a product that will remove this safely?
I'd try a little rubbing alcohol, and a plastic or teflon spudger/spatula.
Are you sure it's not brake dust? Try a wheel cleaner (not the cheap stuff that eats your clearcoat) and a little elbow grease with a rag. Follow up with polish when you've removed the really big bits.
No it isn't brake dust, it is rubber, I was running hard on the PS2's and the track dried up very quickly and the PS2's melted faster then I would have ever imagined. I first thought it was paint or tar, but it is definitely rubber.
I have heard that WD40 works as well, have you tried that?
Anything that lubricates should help you, WD40 or maybe just some dish/car wash soap. I find the rubbing alcohol does well for adhesive, and I've used it for rubber cone marks from AX which is why I suggested it here. lifts the stuff up and doesn't leave a lot of residue to clean.
Turtle Wax has a spray Tar & bug remover which I have found takes off just about anything without harming the paint. This may not be strong enough depending on the amount of rubber stuck to your paint
I use "Oil Flo Saftey Solvent Cleaner." It is water soluable, so you can use it diluted. I've found a lot of the rubber marks come off diluted, but I usually just spray it on and wipe it off, and then rinse real good. It does take the wax off, but I have been using it for 2 years and have not seen any impact on the paint. If you go this route, shop around for it - you can buy it through car care places, but contractors also use it, and I've found it through contractor supply houses cheaper.
I have tried that in the past, it didn't get much stuff off.
I will give this a try, I know where to get some of this stuff.
Not strong enough I guess... Hope you find something that works :D
  • 2 months later...
Goof Off for plastic....orange spray bottle. Works great at taking tire rubber, etc. off of the clear plastic protectors that protect the rear rocker panels, invisible bras, etc. It won't cloud the plastic. Works on the paint too....I always make sure I wash the area really good after applying to get any chemical residue off.
