I'm using a wiring diagram to trace some electrical connections. This is the first time I've spent studying the diagrams.
CP means welding point, according to one of the legend sheets. What is a welding point and why would a wire terminate there?
It is a ground to chassis - usually soldered.
Thanks Loren.
Does anyone know where I would find CP 26 on a 2004 986S?
What diagram were you on? I don't have time to look through them all.
As I interpret it (and of course I may be wrong) CPs aren't always Ground Points. I think CP means Connection Point, and as Loren says, these are usually soldered (~welded~). Ground points are often shown as GP.
If you have a complete set of diagrams for the 2004 986, Sheet 24 shows the location of all the CPs and a grid of where to find them on the car.
Thanks Richard.
Starting to get it now.
For CP 26, sheet 24 says:
Term. 87, DME rear
And places it on the grid at 15cQ
That is where the relay box is, and sure enough, I see the suspect wire heading into a relay and that terminal on the relay is marked 87.
