Hi i have a Cayenne S 2006, today when i stop and accelerate fast in D (Drive) the only i got is the RPM gauge going to 5 Rpm and then i feel hit strong in the back but they dont move.
i think have transmission problems.
Sorry I don't understand your question. Does it upshift hard to the next gear at 5000 RPM or will only rev to 5000??
nop when you are stop complete then you want accelerate fast they don't move forward in D position only does is the sound of the engine (Rev) and when gauge rpm goes down something hit hard in the back of the car.
if you want drive normally the car is ok.
sorry for the bad english :)
thanks
Edited by daury44
You really need to have the system checked for codes and to inspect the fluid level. Does the gear position display ever flash or show an odd display?
i checked , no codes, nothing wrong in the display..
What scan tool did you use to retrieve gear box codes?
i sended to the porsche dealership and they use piwis and change the transmission oil and have the same problem.
they tell me i have to get new transmission :angry:
I would get a second opinion from an independent Porsche specialist.
As Loren suggested, you need a second opinion. Is there another dealer or experienced indy you could visit?
