i have a code pull out from the OBD2 said that i have a misfire on cylinder 4 , i don't have any CEL on the car but once the enghine is hot the engine like tremble
any ideas guys for where is the cylinder 4 located as i wanna check the coil if it's craking , any ideas for help thanks
Mentioning the engine type would be a help, assumption the engine is a V8, cyl.4 is on the right side against the fire wall.
thanks guys
RFM : engine is V8 cayenne S 2004
any special tools guys that i need thanks , i just check the pars number on the left without taking it off yet so iy says 948.602.104.00 , what kind of tool can i use to take that coil off
thanks Loren
thanks guys
thanks Loren
Latest version I see in the parts list is: 948.602.104.05
thanks guys
thanks Loren
thanks Loren,
do you have any idea of the tools i need to take that coil off thanks
thanks guys
thanks Loren
thanks Loren,
Read the TSB here but be aware that the part numbers have changed since that TSB.
The part number I gave you is the latest (.05).
I sent you more detailed instructions via PM.
thanks guys
thanks Loren
thanks Loren,
thanks a lot Loren
