Anyone know if there is a repair manual available for the 2005 Boxster? I couldn't find a Bentley, Chiltons, or Haynes. My temperature guage quit working and I thought I could change the coolent temperature sensor myself, if I can just find the repair manual to guide me along.
You should be able to find a Bently on Amazon (or someone else pipe in). Haynes and all the rest don't make one. If you know your way around the web really well, you can get an early version of the factory manual in pdf for $0-5.
Regards, Peter
Contact porschelibrarian by pm on here & he will sort you out at a very reasonable cost for what you need :) .
regards
