oil filter replacement
george993
when replacing oil filter in 997s does it matter if I insert/seat the stem that contains the small O ring into the oil filter element separate from the oil filter cap?
or should the cap and stem be inserted as one unit?
reason for my question is when I remove the stem that contains the small O ring I noticed that part of the small O ring was cut by its seat edge. I found the remnant sitting next to the O ring receptacle... with the stem attached to the oil filter cap I notice the stem wriggles and when inserted into the oil filter housing it can cause a slight miss alignment and therefor the smaller O ring edge can be cut by the receptacles edge....
Edited by george993
