DME Programming codes Contact of Porshe Distributer USA
Ladies and Gentlemen,
I purchased an engine with a DME and security model from the USA. I live in South Africa. The Porsche distrubitor in South Africa gave me the programming codes for my car, but they do not have access to the codes for the DME I purchsased from the USA. I have the VIN number and proof of purchase.
Can any body please give me some contact details of a distributer in the USA, so that I could contact them to get me the codes I require? I will obviously pay for the service.
Regards
Pieter.
pm me with your vin and car type of the original dme. I will try to contact my friendly dealer. It's not about money. They are not aloud to do it. Did you try the LA dismantlers - where you got the engine from?
Did you change the dme from 5.2.2 to 7.2?
Sergiu
Edited by sergiu
I bought a used control unit, the one that goes under the seat, from ebay. But that thing is worthless without the code. The seller gave me the VIN for the car it came from, and I was able to get the code. In fact I got all the codes for the donor car, including the radio code. But you would need to find a real friendly US dealership.
Sergiu,
I did send numerous e-mails to LA Dismantlers and no reply. (I did buy the engine from them, I must also add that the engine has done 4000km on the 2.5 DME programme and has performed flawlessly)
No, I did not change the DME type. My car (the 2.5 DME) is a 996.618.601.02 (5.2.2) and Porsche SA said that they could not programme it. The new DME is a 996.618.601.04 (5.2.2) which is programmable. I will have to re-programme the .04 DME with my car's security codes.
I did get the security module with the DME (matching VIN numbers) but the plug on the US security module is completely different to my car's plug. So therefore I have to match my security module with the new DME.
Regards
Pieter
Sergiu
Sergiu,
Regards
Pieter
Sergiu
Maybe a PITA -- but consider making an interface connector for the two plugs?
Hi Txhokie4life,
Thanks for the reply.
Sorry, I do not know what PITA means?
This is a possibility but I do not have both security module's connection diagrams. It could be simple as the pins are easily removeable from the plugs, so to change from one plug to another depends on if both security modules have the same signals. I will do a search here and see if I can get the wiring diagrams of both modules.
Regards
Pieter
Sergiu,
Regards
Pieter
Sergiu
Thanks Sergiu,
The guy that has the PIWI's is racing both this weekend and the next. I will have to wait another 2 weeks. He is in Johannesburg and I am in Pretoria so I can only get to him on a Saturday morning. I will let you know how it went.
Regards
Pieter
Just pm'd you.
Let me know if it worked.
Sergiu
