I have a 1999 Boxster. When I turn the key from position 0 to 1 the radio comes on then when I turn it from 1 to 2 the radio goes off. I ordered a 4A0905849 for the ignition. When I tried to install it I found out I needed a 4B0905849 so I sent the part back and got the correct part and found out it did the same as before. The radio works find except when the car is running. Has anyone got and clue what is going on?
The radio is on unswitched power (always has power applied to it). You should be able to turn it on (and off) without the key.
Unless someone has reqired it that is how it should work.
